Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This guide provides step by step instructions on how to replace the internal fan.
Запчасти
Детали не указаны.
  1. Flip the laptop over so the bottom is facing up.
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Gently lift the battery out of the computer.
    • Gently lift the battery out of the computer.
  3. Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Remove the WIFI module cover. It will pull right off.
    • Remove the WIFI module cover. It will pull right off.
  5. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  6. Unplug the white and black wires from the WiFi module. Unplug the white and black wires from the WiFi module.
    • Unplug the white and black wires from the WiFi module.
  7. Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  8. Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  9. Use the plastic opening tool to pry the two halves apart.
    • Use the plastic opening tool to pry the two halves apart.
  10. Remove the three 2 mm Phillips #00 screws that secure the fan to the motherboard.
    • Remove the three 2 mm Phillips #00 screws that secure the fan to the motherboard.
  11. Remove the small plug connecting the fan power cable to the motherboard.
    • Remove the small plug connecting the fan power cable to the motherboard.
    • Carefully lift the fan out of the computer.
Заключение
Еще один человек закончил это руководство.
Cole Uhland
Участник с: 30.09.2013
216 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 14-8, Forte Fall 2013 Участник Cal Poly, Team 14-8, Forte Fall 2013
CPSU-FORTE-F13S14G8
4 членов
Автор 5 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 3
За всё время: 727
