Введение
This is a step by step guide of how to replace the speakers in case of malfunction or upgrade.
  1. Flip the laptop over so the bottom is facing up.
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Gently lift the battery out of the computer.
    • Gently lift the battery out of the computer.
  3. Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Remove the WIFI module cover. It will pull right off.
    • Remove the WIFI module cover. It will pull right off.
  5. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  6. Unplug the white and black wires from the WiFi module. Unplug the white and black wires from the WiFi module.
    • Unplug the white and black wires from the WiFi module.
  7. Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  8. Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  9. Use the plastic opening tool to pry the two halves apart.
    • Use the plastic opening tool to pry the two halves apart.
  10. Locate the plug for the speaker wires on the bottom of the laptop. Locate the plug for the speaker wires on the bottom of the laptop.
    • Locate the plug for the speaker wires on the bottom of the laptop.
  11. Unplug the speaker wire connector.
    • Unplug the speaker wire connector.
  12. Remove the speakers by sliding them straight up. They should slide out with ease.
    • Remove the speakers by sliding them straight up. They should slide out with ease.
Заключение
Cole Uhland
Участник с: 30.09.2013
216 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 14-8, Forte Fall 2013 Member of Cal Poly, Team 14-8, Forte Fall 2013
CPSU-FORTE-F13S14G8
4 членов
Автор 5 руководств
Добавить комментарий
Просмотр статистики:
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
За всё время: 346
