Введение
This replacement guide is to walk you through a battery replacement on your Toshiba Satellite A660-ST3NX2X. Before starting this replacement, make sure you have a replacement battery that is made for this computer. Also, make sure the computer is powered off and completely shut down before completing this replacement.
Выберете то, что вам нужно
Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
Locate the two sliding tabs on either side of the battery.
Using both hands, place one finger on each tab and slide them to the sides and away from each other.
