Toshiba Satellite A660-ST3NX2X Hard Drive Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • Unplug all cables and other devices from the computer before starting this replacement.
    • Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
  2. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: шаг 2, изображение 1 из 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: шаг 2, изображение 2 из 2
    • Locate the two sliding tabs on either side of the battery.
    • Using both hands, place one finger on each tab and slide them to the sides and away from each other.
  3. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: шаг 3, изображение 1 из 3 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: шаг 3, изображение 2 из 3 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: шаг 3, изображение 3 из 3
    • Pull the battery out, keeping the tabs pushed to the side.
    • The right tab on this laptop stayed pushed to the right without needing to be held in place.
  4. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement, Hard Drive: шаг 4, изображение 1 из 1
    • Unplug all devices from your computer and power down the device completely.
    • Flip the computer over so the screen is facing down.
    • In the image, the hard drive will appear to be in the top right corner where the box indicates.
  5. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: шаг 5, изображение 1 из 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: шаг 5, изображение 2 из 2
    • Use a J00 bit to unscrew the single 4mm screw that holds the hard drive cover in place.
  6. Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: шаг 6, изображение 1 из 2 Toshiba Satellite A660-ST3NX2X Hard Drive Replacement: шаг 6, изображение 2 из 2
    • Remove the cover that holds the hard drive in place.
    • Remove the hard drive.
    • This computer contains no hard drive, therefore we are unable to show the physical removal of it.
Заключение
Cassie Pickett
Участник с: 03/20/17
201 Репутация
Автор 2 руководств
Команду
Texas Tech, Team S8-G1, Bennett Spring 2017 Участник Texas Tech, Team S8-G1, Bennett Spring 2017
TTU-BENNETT-S17S8G1
4 членов
Автор 15 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 3
За последние 30 дней: 11
За всё время: 573
