Введение
This replacement guide is to walk you through a screen replacement on your Toshiba Satellite A660-ST3NX2X. Before starting this replacement, make sure you have a replacement screen that is made for this computer. Also, make sure the computer is powered off and completely shut down before completing this replacement.
Выберете то, что вам нужно
Turn the computer over, so the screen is facing down and the battery is positioned in front of you.
Locate the two sliding tabs on either side of the battery.
Using both hands, place one finger on each tab and slide them to the sides and away from each other.
Unscrew all four 5mm screws located underneath the stickers in each corner of the computer frame.
The computer frame should become more loose after the screws are removed.
Pry the frame of the screen away from the computer.
A prying tool was used by inserting it in the crack between the frame and the screen and running it along the edges of the frame.
Unscrew the three black 4mm JIS screws on each side of the metal frame that is still attached to the side of the screen.
Only two screws are shown in the image.
The metal frame will completely separate from the computer screen.
Position the screen in a way that the aluminum backing is exposed.
Peel off the metal-like attachment from the back of the screen.
