Toshiba Satellite A665-S5170 RAM Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite A665-S5170 RAM Replacement, RAM: шаг 1, изображение 1 из 1
    • Turn your computer upside down so that the bottom of your laptop is facing up.
    • Position your laptop so that you are able to read the words printed on the labels on the bottom of the computer from left to right.
    • Using a Phillips head 0 screw driver, remove the 2mm Phillips head screw at the bottom edge of the RAM panel (located in the center of the bottom of the laptop) by rotating the screw counterclockwise.
  2. Toshiba Satellite A665-S5170 RAM Replacement: шаг 2, изображение 1 из 2 Toshiba Satellite A665-S5170 RAM Replacement: шаг 2, изображение 2 из 2
    • Insert something thin, such as your fingernail or a credit card, into the slot at the bottom edge of the RAM panel.
    • Pull up with your hand until the cover of the RAM panel pops out of place and can be removed completely.
  3. Toshiba Satellite A665-S5170 RAM Replacement: шаг 3, изображение 1 из 2 Toshiba Satellite A665-S5170 RAM Replacement: шаг 3, изображение 2 из 2
    • With your thumbs, press down on the small silver clamps on the left and right edges of the upper green RAM chip until the clamps release the chip.
    • When the chip is released, it will pop up and stick out at a 45 degree angle from the computer.
  4. Toshiba Satellite A665-S5170 RAM Replacement: шаг 4, изображение 1 из 1
    • Remove the upper RAM chip from its socket by gently gripping the left and right edges with your fingers and pulling the chip towards your body until it slides completely free of the computer.
  5. Toshiba Satellite A665-S5170 RAM Replacement: шаг 5, изображение 1 из 2 Toshiba Satellite A665-S5170 RAM Replacement: шаг 5, изображение 2 из 2
    • With your thumbs, press down on the small silver clamps on the left and right edges of the lower green RAM chip until the clamps release the chip.
  6. Toshiba Satellite A665-S5170 RAM Replacement: шаг 6, изображение 1 из 1
    • Remove the lower RAM chip from its socket by gently gripping the left and right edges with your fingers and pulling the chip towards your body until it slides completely free of the computer.
Заключение
Еще один человек закончил это руководство.
Will Peterson
Участник с: 10/31/16
121 Репутация
1 руководство автора
Команда
Baylor, Team 4-5, Williams Fall 2016 Участник Baylor, Team 4-5, Williams Fall 2016
BU-WILLIAMS-F16S4G5
3 членов
Автор 12 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 12
За всё время: 797
