Введение
Use this guide to replace or install the hard drive in your Toshiba laptop.
Выберете то, что вам нужно
Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
Unlock the battery by sliding the tab shown to the right
Slide the tab shown to the left and remain holding it.
Place your thumb on the grips of the battery as shown.
While holding onto the grips, pull the battery towards you and away from the laptop.
Locate 5mm Philips #0 screw on hard drive cover.
Remove these two 5mm Phillips #0 screws using the Phillips #0 Screwdriver.
Insert the plastic opening tool into the tab shown and lift up to remove the lower left plate.
Use plastic opening tool to lift hard drive out of case.
Lift the left side of the hard drive and slide it out towards the left.
