Toshiba Satellite A85-S107 15" Wireless Card Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite A85-S107 15" Wireless Card Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Power off the laptop.
    • Disconnect the power cable from the laptop. If you do not, electric shock may result.
  2. Toshiba Satellite A85-S107 15" Wireless Card Replacement: шаг 2, изображение 1 из 1
    • Flip the laptop over and orient it such that the battery faces towards you and the front faces away from you as shown in the diagram.
    • Unlock the battery by sliding the tab shown to the right.
    • This tab will latch into place.
  3. Toshiba Satellite A85-S107 15" Wireless Card Replacement: шаг 3, изображение 1 из 1
    • Slide the tab shown to the left and remain holding it.
    • This tab does not lock into place like in the first step.
    • Place your thumb on the grips of the battery as shown.
    • While holding onto the grips, pull the battery towards you and away from the laptop.
  4. Toshiba Satellite A85-S107 15" Wireless Card Replacement: шаг 4, изображение 1 из 2 Toshiba Satellite A85-S107 15" Wireless Card Replacement: шаг 4, изображение 2 из 2
    • Loosen this 5 mm Phillips #0 screw found in the center of the lower case.
    • The screw will not come out completely, it will stay connected to the center plate.
  5. Toshiba Satellite A85-S107 15" Wireless Card Replacement: шаг 5, изображение 1 из 1
    • Remove the center plate by lifting it and sliding it to the right.
    • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that the screw is loose before attempting again.
  6. Toshiba Satellite A85-S107 15" Wireless Card Replacement: шаг 6, изображение 1 из 1
    • The computer should be open with many of the internal components shown. You can now access the RAM, and wireless card.
  7. Toshiba Satellite A85-S107 15" Wireless Card Replacement, Wireless Card: шаг 7, изображение 1 из 2 Toshiba Satellite A85-S107 15" Wireless Card Replacement, Wireless Card: шаг 7, изображение 2 из 2
    • Carefully pull the white auxiliary wire out of its socket on the wireless card.
    • Now repeat this step with the black auxiliary wire.
    • Be careful when removing the wires, as the wireless card and the wires are delicate.
  8. Toshiba Satellite A85-S107 15" Wireless Card Replacement: шаг 8, изображение 1 из 2 Toshiba Satellite A85-S107 15" Wireless Card Replacement: шаг 8, изображение 2 из 2
    • Push the two black tabs, located on the sides of the card, away from the card.
    • The right side of the wireless card should now pop out of its holder.
    • Pull the wireless card out by lifting it from the dock and sliding it towards the right.
Заключение
Travis
Участник с: 04/13/13
31 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 10-38, Amido Spring 2013 Участник Cal Poly, Team 10-38, Amido Spring 2013
CPSU-AMIDO-S13S10G38
4 членов
Автор 24 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 16
За всё время: 734
