Введение
In this guide, you will use a pry tool and a Phillips screwdriver to get to the power jack in order to replace or clean it. Should your power jack be defective or damaged, you can replace it with a new one.
Выберете то, что вам нужно
Push and hold button 2 to the left.
As you push button 2 to the left position, simultaneously lift up the battery pack.
Locate the power jack at the back, right-hand side next to the USB port.
Еще один человек закончил это руководство.
