Введение
In this guide, you will learn how to replace the RAM in your computer, using a screwdriver and a plastic opening tool.
Выберете то, что вам нужно
Push and hold button 2 to the left.
As you push button 2 to the left position, simultaneously lift up the battery pack.
The RAM should now be at a 30 degree angle.
Using your fingers, unclip the top two clips.
The RAM should just pop out. You can remove it with your fingers.
Еще один человек закончил это руководство.
