Введение
This guide will walk you through the process to replace your RAM.
Выберете то, что вам нужно
Press down with your fingers while also applying a sliding motion on the latch buttons near the battery on the underside of your laptop.
Place the laptop with the bottom facing up.
Observe the single 6mm Phillips #1 screw keeping the laptop panels in place.
Using your Phillips #1 screwdriver, unscrew the 6mm screw on the panel, exposing the hard drive and RAM.
Once the ram chip is exposed, push the two clips away from the ram chip to release it. (Clips move in direction of arrows.)
The ram chip will tilt up after the clips are released.
Using your fingers, pull the ram chip out at a slight angle.
2 участников успешно повторили данное руководство.
