Toshiba Satellite C55-A5140 Battery Replacement
  1. Toshiba Satellite C55-A5140 Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Make sure the device is unplugged, completely off, and not warm to the touch.
    • Check for any visible battery defects such as bulges, bends or cracking as they could be signs of a leaking or deformed battery.
    • Do not handle a deformed battery. Deformed batteries can cause burns and exposure to harmful chemicals.
    • Flip device over and locate two switches on the back of the device.
  2. Toshiba Satellite C55-A5140 Battery Replacement: шаг 2, изображение 1 из 2 Toshiba Satellite C55-A5140 Battery Replacement: шаг 2, изображение 2 из 2
    • Slide switch 1 towards the unlock symbol on the device (switch should click into place).
    • Slide switch 2 towards the unlocked symbol on the device.
    • While holding switch 2 in the unlocked position, use the notch located at the top of the battery to pull battery out and away from the device.
    • Switch 2 does not lock into place and will need to be held in unlocked position.
  3. Toshiba Satellite C55-A5140 Battery Replacement: шаг 3, изображение 1 из 1
    • Pull battery free from device and release switch 2.
Заключение
To reassemble your device, follow these instructions in reverse order. When inserting new battery make sure to align bottom of battery with the slot first before inserting battery
Cameron Chapman
Участник с: 09/27/17
533 Репутация
Автор 5 руководств
Команда
Eastern Washington University, Team S1-G5, Carnegie Fall 2017 Участник Eastern Washington University, Team S1-G5, Carnegie Fall 2017
EWU-CARNEGIE-F17S1G5
3 членов
Автор 15 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 9
За всё время: 347
