Введение
This guide will show you how to remove or replace the optical disc drive of the Toshiba Satellite C55-A5286 laptop. A Phillips screwdriver of head size PH0 is required for this guide.
Выберете то, что вам нужно
Unscrew the only screw (5 mm) that is holding on the removable back panel and remove the back panel.
Remove the two 5-mm screws near the disk drive on the back panel. These two screws are above and below the manufacturer’s sticker.
2 участников успешно повторили данное руководство.
Один комментарий
Not a medium effort at all - very easy.
…although, I did have to use an iFixt It needle-nose tweezer to pull the middle 5mm screw out after it was unscrewed - it would not fall out nor did it cling to the screwdriver.
