Введение
A hard drive replacement guide for a Toshiba Satellite C55-B5200 laptop.
Выберете то, что вам нужно
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Remove the two 4.6mm Phillips #0 screws from disk drive.
Lift the disk drive and pull out to remove.
5 человек успешно провели ремонт по этому руководству.
2 Комментариев
Pablo, you didn’t mention that you must remove all the screws to get at the hard drive. What a pain. Other satellites have compartments the c55 that i have you must take every screw out as the back is one piece. Thanks for the instructions.
Dónde puedo comprar el disco duro de una laptop toshiba satellite C55
