Введение
Standard Keyboard with 10-key and touchpad with multi-touch control
Выберете то, что вам нужно
Turn the laptop off and remove all sources of power.
Flip the laptop over so that way the bottom is facing towards you.
Remove the two 6.6mm Phillips #0 screws from the battery.
Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
Remove the six 2.3mm Phillips #0 screws from the motherboard.
Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
Disconnect the wires from the motherboard.
Lift and remove the disk drive.
Lift and remove the hard drive.
Lift up the motherboard
Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
Use a plastic opening tool to unlatch the keyboard from the device
Lift the keyboard off the laptop, careful of the IDE ribbon cable
2 участников успешно повторили данное руководство.
