Введение
Use this guide to remove the fan from your Toshiba Satellite C55-B5302 laptop. You will need a #0 and #00 Phillips screwdriver and a plastic pry tool. Make sure your laptop is unplugged and cool before you start. The fan is easy to remove and should take 10 to 20 minutes.
Выберете то, что вам нужно
Using the Phillips #0 screwdriver, remove the two 7 mm screws from the back casing.
Remove the remaining 7 mm screws on the back panel of the laptop with a Phillips #0 screwdriver.
Use the plastic opening tool to pry up a corner of the back panel and continue to pop the back panel off.
Remove the three 3 mm screws with a Phillips #00 screwdriver.
Remove the 5 mm screw with a Phillips #0 screwdriver.
