Введение
Whether or not you are upgrading your storage or the hard drive is out of commission, this guide will help you remove it.
Выберете то, что вам нужно
Pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
Unscrew the ten 6.5mm PH1 Phillips head screws that hold down the back cover.
Using the plastic opening tools, open the back cover and remove it from the laptop.
The hard drive is on the bottom left side.
Remove both releases from the rubber hard drive mount.
Lift the hard drive from underneath on the right side.
While holding it up, pull it away from its connector so that it disconnects.
5 участников успешно повторили данное руководство.
