Toshiba Satellite C55-C5268 Disk Drive Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite C55-C5268 Disk Drive Replacement, Battery: шаг 1, изображение 1 из 1
    • Unplug and power off the laptop.
    • Unscrew the two 9 mm Phillips #1screws holding the battery in place.
  2. Toshiba Satellite C55-C5268 Disk Drive Replacement: шаг 2, изображение 1 из 2 Toshiba Satellite C55-C5268 Disk Drive Replacement: шаг 2, изображение 2 из 2
    • Grab the battery and pull it away from the laptop to remove it.
    • This doesn't require a lot of effort, so you don't have to pull too hard.
  3. Toshiba Satellite C55-C5268 Disk Drive Replacement, Back Panel: шаг 3, изображение 1 из 1
    • Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
  4. Toshiba Satellite C55-C5268 Disk Drive Replacement: шаг 4, изображение 1 из 2 Toshiba Satellite C55-C5268 Disk Drive Replacement: шаг 4, изображение 2 из 2
    • Using a metal spudger can damage sensitive components.
    • Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
  5. Toshiba Satellite C55-C5268 Disk Drive Replacement: шаг 5, изображение 1 из 2 Toshiba Satellite C55-C5268 Disk Drive Replacement: шаг 5, изображение 2 из 2
    • Pry up the back panel from the rest of the laptop using a spudger.
    • It is best to start around the USB port and work your way around the edge until the panel completely snaps off.
  6. Toshiba Satellite C55-C5268 Disk Drive Replacement, Disk Drive: шаг 6, изображение 1 из 1
    • Unscrew one 3.0 mm screw from the disk drive using a #1 Phillips screwdriver.
  7. Toshiba Satellite C55-C5268 Disk Drive Replacement: шаг 7, изображение 1 из 2 Toshiba Satellite C55-C5268 Disk Drive Replacement: шаг 7, изображение 2 из 2
    • Grab the disk drive with one hand and the laptop with another, then gently pull the disk drive straight toward yourself.
    • Pull it in a straight line horizontally until it is completely removed.
    • This does not require much force, so be gentle.
Заключение
Ben Rounseville
Участник с: 10/21/16
471 Репутация
Автор 4 руководств
Команду
UMass Dartmouth, Team 4-1, Catania Fall 2016 Участник UMass Dartmouth, Team 4-1, Catania Fall 2016
UMASSD-CATANIA-F16S4G1
2 членов
Автор 12 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 416
