Введение
This guide will show you how to correctly replace the Disk Drive.
Выберете то, что вам нужно
Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
Unscrew one 3.0 mm screw from the disk drive using a #1 Phillips screwdriver.
Grab the disk drive with one hand and the laptop with another, then gently pull the disk drive straight toward yourself.
