Введение
The hard drive of a laptop is where all the data is stored. From your operating system to those pictures of your dogs, it's all located within this unassuming gizmo. If a hard drive fails, it can be catastrophic. Be sure to back up important data regularly!
Выберете то, что вам нужно
Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
Pull the two rubber stops upward to move them out of the way and free the hard drive.
Slide the hard drive to the right towards the stops. This disconnects it from the motherboard.
8 участников успешно повторили данное руководство.
