Введение
This guide will show you how to properly remove and replace the Heat Sinks.
Выберете то, что вам нужно
Unscrew the 10 9.0 mm screws holding the back panel on using a Phillips head #1 screwdriver.
Insert a metal spudger tool in the seam between the back cover and the laptop itself. Gently run the spudger around the edge to pop the cover off.
Unscrew the four 5.0 mm screws holding the heat sink in place using #1 Phillips screwdriver.
