Выберете то, что вам нужно
Push the left tab with your left hand.
Then push the right tab with your right hand.
While your right hand is still pushing, remove the battery with your left hand.
Remove the panel with the plastic opening tool. Make sure you lift it on all four sides.
Once keyboard is popped out, use a nylon spudger to undo the ribbon or flap that attaches the back of the keyboard to the inside base of the laptop.
3 человек успешно провели ремонт по этому руководству.
2 Комментариев
Step has the incorrect screw to release the keyboard. There is no need to open the back panel. The screw which holds down the keyboard is the long screw between the Serial Number sticker and the battery release switch #2.
Agreed 100%. Good thing I looked at this comment before I ran into major trouble. Thank you!
