Введение
Is your battery no longer working and in need of a replacement? This guide will give you step by step instructions to switch out your battery for the Toshiba Satellite C55D-A5201.
Выберете то, что вам нужно
Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
5 участников успешно повторили данное руководство.
