Введение
This guide teaches you how to remove your keyboard. Reverse the steps to replace with a new keyboard.
Выберете то, что вам нужно
Close the laptop, and flip it upside down. You want the spine to be furthest away from you.
Slide the right slider to the right, and simultaneously, pull the battery out at a diagonal angle.
Slip the plastic opening tool under the "Enter" key on the right corner of the keyboard.
Lift the plastic opening tool up until the corner of the keyboard is detached.
Slide the plastic opening tool slowly along the bottom of the keyboard towards the left.
Continue up the left side of the keyboard.
Lift the keyboard up by grabbing it on both sides.
Set the keyboard against the laptop screen.
Using tweezers, push up the two black switches on either side of the ZIF connector.
13 участников успешно повторили данное руководство.
