Toshiba Satellite C55D-B5206 Hard Drive Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 2, изображение 1 из 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 2, изображение 2 из 2
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Back Casing: шаг 3, изображение 1 из 1
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 4, изображение 1 из 1
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 5, изображение 1 из 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 5, изображение 2 из 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 5, изображение 3 из 3
    • Using fingers remove the casing.
  6. Toshiba Satellite C55D-B5206 Hard Drive Replacement, Hard Drive: шаг 6, изображение 1 из 1
    • Once the device is open from the bottom, look for the bright blue plastic frame which encases the hard drive
  7. Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 7, изображение 1 из 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 7, изображение 2 из 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 7, изображение 3 из 3
    • Locate the four side plugs of the blue plastic casing which secure the hard drive in place.
    • Unplug the four clips by gently pulling them upward.
  8. Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 8, изображение 1 из 2 Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 8, изображение 2 из 2
    • Gently slide the hard disk towards the right side of your laptop.
    • The hard disk drive should now be free from the black connector port.
  9. Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 9, изображение 1 из 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 9, изображение 2 из 3 Toshiba Satellite C55D-B5206 Hard Drive Replacement: шаг 9, изображение 3 из 3
    • Gently lift the hard drive upward, removing it from the Toshiba device.
    • The hard disk should now be completely removed from the Toshiba Satellite C55D device.
Заключение
7 человек успешно провели ремонт по этому руководству.
Michelle
Участник с: 09/17/15
175 Репутация
1 руководство автора
Команду
CSU Fullerton, Team 2-5, Bruce Fall 2015 Участник CSU Fullerton, Team 2-5, Bruce Fall 2015
CSUF-BRUCE-F15S2G5
4 членов
Автор 18 руководств
2Комментарии к руководству
Thanks.. Really helped out..
SpeedyBlanco - Ответить
I opened the Toshiba but the HD unit & tie downs are a little bit different. Can I send you a picture or do facetime perhaps so you can easily see?
myfinman - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 0
За последние 7 дней: 1
За последние 30 дней: 36
За всё время: 4,854
