Введение
This guide will show you how to easily remove the Track Pad from a Toshiba Satellite C55D-B5206. This is a very easy process as shown in this guide.
Выберете то, что вам нужно
Turn the laptop upside down so the battery faces upwards.
Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
Use a non-metallic object to remove the yellow polyimide tape that covers the trackpad connector.
Use a non-metallic object to lift up the gray ZIF tab on trackpad connector.
Gently pull the blue ribbon cable free.
Push the two gray tabs out on the large wire plug shown.
The plug can now be carefully pulled out.
