Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Battery: шаг 1, изображение 1 из 2 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Battery: шаг 1, изображение 2 из 2
    • Turn the laptop upside down so the battery faces upwards.
    • Use a Phillips #1 screwdriver to remove the two, 7 mm screws that secure the battery.
  2. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 2, изображение 1 из 2 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 2, изображение 2 из 2
    • Place both of your thumbs on the outside edges of the battery and push the battery out to remove it.
    • The battery should slide out with little resistance.
  3. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Back Casing: шаг 3, изображение 1 из 1
    • Use the screwdriver to remove the thirteen, 7 mm Phillips#1 screws from the bottom of the chassis.
  4. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 4, изображение 1 из 1
    • Insert a spudger at the center and into the crevice between the bottom casing and the keyboard and pry upwards.
    • Gently slide the spudger along the entire perimeter of the device and pry the casing loose to unhook 6 clips.
    • These images show a metal spudger, which has the potential to damage the device. Use a plastic opening tool or standard spudger instead.
    • Do not be alarmed if you feel a gentle tug or hear a click as you slide your spudger. These sounds are the clips detaching from the casing.
  5. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 5, изображение 1 из 3 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 5, изображение 2 из 3 Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 5, изображение 3 из 3
    • Using fingers remove the casing.
  6. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement, Wi-Fi Card: шаг 6, изображение 1 из 1
    • Unstick the silver tape from the area shown using a non-metallic tool.
  7. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 7, изображение 1 из 1
    • Remove the yellow tape to reveal the plug for the flat strip of wires.
  8. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 8, изображение 1 из 1
    • Locate the gray clips at either side of the plug. Use a non-metallic tool to push the clips away from the plug.
  9. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 9, изображение 1 из 1
    • Unplug the large strip of wires. Lift the large strip of wires out of the way to reveal the Wi-Fi Card.
  10. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 10, изображение 1 из 1
    • Use a non metallic item to pry up on the two metal clips holding the black and white wires. These should pop straight up and will be free from the Wifi Card.
  11. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 11, изображение 1 из 1
    • Use a small Philips screwdriver to remove the screw shown.
  12. Toshiba Satellite C55D-B5206 Wi-Fi Card Replacement: шаг 12, изображение 1 из 1
    • The Wi-Fi Card can now be unplugged from it's port and removed.
Заключение
Elaine Butler
Участник с: 04/12/22
265 Репутация
Автор 2 руководств
Команду
IUPUI, Team 1-2, Beck Spring 2022 Участник IUPUI, Team 1-2, Beck Spring 2022
IUPUI-BECK-S22S1G2
4 членов
Автор 12 руководств
0Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 3
За последние 7 дней: 8
За последние 30 дней: 30
За всё время: 713
