Введение
If the fan is excessively noisy or non-operational, use this guide to remove and replace the fan.
Выберете то, что вам нужно
Now begin to remove the coverings above and below the middle plate with your hand.
use your hand or a tool to remove the tabbing on the metal plate covering the battery.
grab your replacement keyboard and connect it to the backing of the old keyboard.
once placed, hold the keyboard onto the phone while clicking the two metal plates back down to connect the keyboard.
Remove the remaining thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
Remove the three 3 mm Phillips screws holding the fan cable in place using the PH1 bit and Magnetic Driver.
Lift the fan cable connector from the fan.
Remove the fan from the plug by releasing the clamps located on each side of the socket.
Slide the connector out of the socket.
Lift the computer fan from the motherboard.
