Введение
If the hard drive in your laptop begins to make a loud clicking noise known as "the Click of Death", use this guide to remove and replace your hard drive.
Выберете то, что вам нужно
Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
Use a Phillips #1 screwdriver (PH1 bit) to remove the thirteen 7 mm screws that secure the bottom cover.
Using the ribbon beneath the hard drive lift it upwards and pull the hard drive out.
6 участников успешно повторили данное руководство.
