Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Flip the phone over so that the back camera is facing you.
Use your phillips screwdriver to begin removing all the accesible screws.
Now begin to remove the coverings above and below the middle plate with your hand.
use your hand or a tool to remove the tabbing on the metal plate covering the battery.
Use your wedging tool to begin removeing the adhesive under the battery.
Begin to use the wedging tool to remove the space bar off of the keyboard.
remove the screws on each end of the space bars vacant lcoation.
grab your replacement keyboard and connect it to the backing of the old keyboard.
once placed, hold the keyboard onto the phone while clicking the two metal plates back down to connect the keyboard.
Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
Remove the remaining thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
Using the plastic opening tools, separate the back cover from the laptop.
Remove the three 3 mm Phillips screws holding the fan cable in place using the PH1 bit and Magnetic Driver.
Lift the fan cable connector from the fan.
Remove the fan from the plug by releasing the clamps located on each side of the socket.
Slide the connector out of the socket.
Lift the computer fan from the motherboard.
Using the ribbon beneath the hard drive lift it upwards and pull the hard drive out.
The white touchpad ribbon must be disconnected from the motherboard connection socket.
Release the two clamps holding the ribbon in place.
Slide the ribbon from the motherboard connection socket.
Remove the white ribbon connecting the USB ports to the motherboard.
Release the two holding clamps.
Slide the ribbon out of the motherboard holding socket.
Remove the 7 mm Phillips screw holding the USB Driver to the motherboard using the PH1 bit and Magnetic Driver.
Remove the blue ribbon connecting the hard drive hardware to the motherboard by first lifting the yellow protective tape.
Slide the blue ribbon from its connection socket.
Carefully separate the securing tape from the ribbon attaching the keyboard to the motherboard.
Slide the keyboard ribbon through its holding slot, completely releasing it from the laptop.
