Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
If you are unable to use the touchpad of your laptop, use this guide to remove and replace the touchpad.
  1. Turn off your laptop before starting. Flip the laptop over so the model stickers face the ceiling.
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face the ceiling.
  2. Use a Phillips #1 screwdriver (PH1 bit) to remove the two 7 mm screws that secure the battery. Use a Phillips #1 screwdriver (PH1 bit) to remove the two 7 mm screws that secure the battery. Use a Phillips #1 screwdriver (PH1 bit) to remove the two 7 mm screws that secure the battery.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the two 7 mm screws that secure the battery.
  3. Carefully slide the battery out of the laptop. Carefully slide the battery out of the laptop.
    • Carefully slide the battery out of the laptop.
  4. Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
    • Use a Phillips #1 screwdriver (PH1 bit) to remove the single 7 mm screw that secures the CD/DVD drive.
  5. Наборы переключателей Nintendo
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Slide the CD/DVD Drive out of the laptop. Slide the CD/DVD Drive out of the laptop.
    • Slide the CD/DVD Drive out of the laptop.
  7. Remove the thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
    • Remove the thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
  8. Using the plastic opening tools, separate the back cover from the laptop. It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Using the plastic opening tools, separate the back cover from the laptop.
    • It is recommended that you start from a corner and run the tool along the edge of the cover.
    • Be careful not to bend or crack the plastic back cover.
  9. Release the clamps holding the white ribbon between the touchpad component and the motherboard. Slide the ribbon from the motherboard connection socket.
    • Release the clamps holding the white ribbon between the touchpad component and the motherboard.
    • Slide the ribbon from the motherboard connection socket.
  10. Remove the two 7 mm Phillips screws holding the touchpad component to the back panel using the PH1 bit and Magnetic Driver.
    • Remove the two 7 mm Phillips screws holding the touchpad component to the back panel using the PH1 bit and Magnetic Driver.
  11. Release the two clamps connecting the blue ribbon to the external touchpad. Lift the black clasp holding the blue ribbon in place.
    • Release the two clamps connecting the blue ribbon to the external touchpad.
    • Lift the black clasp holding the blue ribbon in place.
  12. Slide the blue ribbon from the external touchpad holding socket. Lift the touchpad module from the laptop.
    • Slide the blue ribbon from the external touchpad holding socket.
    • Lift the touchpad module from the laptop.
Заключение
Crystal Loomis
Участник с: 22.01.2018
684 Репутация
Автор 5 руководств
Команда
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 5
За последние 30 дней: 9
За всё время: 344
