Введение
In the case you need to replace the disk drive of your Toshiba Satellite C55D-C5106, this guide will aid you through the process.
Выберете то, что вам нужно
Turn the laptop off and remove any external power sources.
Flip the laptop upside down.
Remove all of the 12 screws that secure the back cover to the laptop with a Phillips #1 screwdriver.
Pull the battery toward yourself until it is completely removed from the laptop. The battery should detach easily.
Run the metal spudger around the seam between the back cover and the rest of the laptop.
