Введение
If you are having issue with your RAM, this guide will walk you through replacing the parts. The only tool needed is a PH1 Philips head screwdriver.
Выберете то, что вам нужно
To remove the RAM sticks, put your thumbs on the metal pins and push outwards.
Once pushed outwards, the first RAM stick will pop up at an angle
After the RAM is at an angle, you can now remove that stick of RAM and repeat the process to the second stick of RAM.
Еще один человек закончил это руководство.
