Введение
If your device has a short battery life, or does not hold a charge at all, you may need to replace your battery. This guide will help you remove your old, worn battery, and replace it with a new, fresh battery in your Toshiba Satellite C655D-S5084.
Turn the device bottom-side up. Make sure the batter compartment is nearest you.
Unlock the right side of the battery.
Unlock the left side of the battery compartment by pushing and holding the button.
Remove the battery.
Еще один человек закончил это руководство.
