Введение
Is your computer getting too hot to handle? Overheating is a sign that your cooling fan may not be working properly, which may cause further damage to your computer. This guide will help you through the replacement of the cooling fan in your Toshiba Satellite C655D-S5084.
Выберете то, что вам нужно
Turn the device bottom-side up. Make sure the batter compartment is nearest you.
Unlock the right side of the battery.
Unlock the left side of the battery compartment by pushing and holding the button.
Remove the battery.
Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
Remove the plastic cover.
Remove the 2.5 mm screw (F3) inside the hard drive casing using the Phillips #1 screwdriver.
Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
Wedge a plastic opening tool between the laptop and the CD drive.
Gently pull the CD drive out.
Remove the 5.5 mm (F5) screw with the Phillips #1 screwdriver.
Remove the fourteen 6.0 mm (F6) screws from the back panel using the Phillips #1 screwdriver.
Remove the two 2.0 mm screws underneath the CD-Rom drive, using the Phillips #1 screwdriver
Release the two tabs using a Phillips #1 screwdriver and the plastic opener.
Remove the wide black ribbon in the same manner as the previous step.
Release all other catches.
9 участников успешно повторили данное руководство.
Один комментарий
Excellent description and very precise. I also upgraded to dual Wifi/ Bluetooth (easy to obtain now, lol). Thanks again!
