Toshiba Satellite C655D-S5084 Cooling Fan Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite C655D-S5084 Cooling Fan Replacement, Battery: шаг 1, изображение 1 из 1
    • Turn the device bottom-side up. Make sure the batter compartment is nearest you.
    • Unlock the right side of the battery.
  2. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 2, изображение 1 из 1
    • Unlock the left side of the battery compartment by pushing and holding the button.
    • Remove the battery.
  3. Toshiba Satellite C655D-S5084 Cooling Fan Replacement, Hard Drive: шаг 3, изображение 1 из 2 Toshiba Satellite C655D-S5084 Cooling Fan Replacement, Hard Drive: шаг 3, изображение 2 из 2
    • Remove the 5.5 mm (F5) screw using the Phillips #0 screwdriver.
    • Remove the plastic cover.
    • The screw may be connected to the cover. If so, loosen it, remove the cover and proceed to the next step.
  4. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 4, изображение 1 из 1
    • Remove the 2.5 mm screw (F3) inside the hard drive casing using the Phillips #1 screwdriver.
    • The screw is located on the small metal tab of the hard drive.
  5. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 5, изображение 1 из 1
    • Slide the large metal tab on the hard drive away from its attachment.
    • With the battery compartment on your left, use your thumb to slide the tab towards you.
  6. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 6, изображение 1 из 1
    • Lift the large metal tab on the hard drive to remove completely.
    • Do not lift until the hard drive is completely free from its base attachment, otherwise you may damage the base.
  7. Toshiba Satellite C655D-S5084 Cooling Fan Replacement, CD/DVD Drive: шаг 7, изображение 1 из 1
    • Turn laptop over and remove the 2.5mm "F3" screw using a Phillips #1 screwdriver.
  8. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 8, изображение 1 из 1
    • This step is shown after rotating the device 90 degrees so that the CD drive is closest to you.
    • Wedge a plastic opening tool between the laptop and the CD drive.
    • Gently pull the CD drive out.
  9. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 9, изображение 1 из 1
    • Carefully remove the CD drive completely by pulling out with your hands.
    • The CD drive should come out easily with little force. If there is any resistance double check if 2.5mm "F3" screw is removed completely.
  10. Toshiba Satellite C655D-S5084 Cooling Fan Replacement, Cooling Fan: шаг 10, изображение 1 из 2 Toshiba Satellite C655D-S5084 Cooling Fan Replacement, Cooling Fan: шаг 10, изображение 2 из 2
    • Remove the 5.5 mm (F5) screw with the Phillips #1 screwdriver.
  11. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 11, изображение 1 из 1
    • Remove the two 6.0 mm (F6) screws with the Phillips #1 screwdriver.
  12. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 12, изображение 1 из 1
    • Remove the fourteen 6.0 mm (F6) screws from the back panel using the Phillips #1 screwdriver.
  13. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 13, изображение 1 из 1
    • Remove the two 6.0 mm golden (F6) screws shown underneath the battery.
  14. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 14, изображение 1 из 1
    • Release the three tabs underneath the battery, using the prying tool.
  15. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 15, изображение 1 из 1
    • Remove the two 2.0 mm screws underneath the CD-Rom drive, using the Phillips #1 screwdriver
    • Release the two tabs using a Phillips #1 screwdriver and the plastic opener.
  16. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 16, изображение 1 из 1
    • Release all internal latches by working the slack around the motherboard.
  17. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 17, изображение 1 из 1
    • Remove the tabs holding the white ribbon in place.
    • A small tool may be required.
  18. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 18, изображение 1 из 1
    • Remove the wide black ribbon in the same manner as the previous step.
    • Release all other catches.
  19. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 19, изображение 1 из 1
    • Detach the white plug by firmly pulling it.
  20. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 20, изображение 1 из 1
    • Detach the other white plug in the same manner as the previous step.
  21. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 21, изображение 1 из 1
    • Remove the three 2.0 mm screws that are holding the fan in place.
  22. Toshiba Satellite C655D-S5084 Cooling Fan Replacement: шаг 22, изображение 1 из 1
    • Detach the white plug attached to the cooling fan.
    • Remove the fan and clean.
Заключение
9 участников успешно повторили данное руководство.
Shelby Kunz
Участник с: 04/19/13
69 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 2-20, Maness Spring 2013 Участник Cal Poly, Team 2-20, Maness Spring 2013
CPSU-MANESS-S13S2G20
4 членов
Автор 15 руководств
Один комментарий
Excellent description and very precise. I also upgraded to dual Wifi/ Bluetooth (easy to obtain now, lol). Thanks again!
Robert Mackey - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 15
За всё время: 7,979
