Введение
If your keyboard module is malfunctioning, you'll need to replace it. You’ll need a PH0 screwdriver and a rigid pry tool. The process itself is easy, just pay special attention when gently opening the ZIF connector.
Выберете то, что вам нужно
Flip the laptop over, so that the "top" of the laptop is against your working surface.
Orient the laptop so that the silver label is in the bottom-left corner, with the battery facing you.
On the right side of the battery, move the tab marked 1 to the right, unlocking the battery.
On the left side of the battery, hold the tab marked 2 to the left while pulling the battery towards you.
Starting at the right, pry up part of the plastic bar by using a spudger between the F12 and Insert key.
Pull up on the rest of the plastic bar to remove it.
Once screws are removed, lift the keyboard closest to the screen and gently flip it over.
Using the spudger, lift up the white ZIF connector to unlatch the ribbon cable, and gently remove the cable.
