Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
How to replace the Keyboard on Toshiba Satellite, series 850.
The video manual is for cleaning the cooling system, but you can follow it, because at the beginning you can see how to disassemble the keyboard.
Please SUBSCRIBE to my channel ツ
Запчасти
Детали не указаны.
Видео обзор
  1. Switch-off the laptop and remove the battery. Switch-off the laptop and remove the battery.
    • Switch-off the laptop and remove the battery.
  2. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  3. The Keyboard is held by 7x locking clips. Use cutter and plastic tools to unlock them. The Keyboard is held by 7x locking clips. Use cutter and plastic tools to unlock them. The Keyboard is held by 7x locking clips. Use cutter and plastic tools to unlock them.
    • The Keyboard is held by 7x locking clips. Use cutter and plastic tools to unlock them.
    I was disassembling a c-850 laptop but it was obvious that the kb is firmly fixed! Finally i found there are four screws on the top part of kb, hidden under a plastic strip . I’d add a photo…but no “attach” button here
    asaf c - Ответить
  4. Disconnect the old Keyboard and you are ready to install the new one. To remove or re-insert the keyboard ribbon, simply flip the locking clip upwards to unlock and downwards to lock the ribbon. Alternatively, you may pull it outwards with a fingernail.
    • Disconnect the old Keyboard and you are ready to install the new one.
    • To remove or re-insert the keyboard ribbon, simply flip the locking clip upwards to unlock and downwards to lock the ribbon. Alternatively, you may pull it outwards with a fingernail.
    • Please SUBSCRIBE to my channel ツ
Заключение
11 участников успешно повторили данное руководство.
ZFix
Участник с: 09.12.2013
172 424 Репутация
Автор 307 руководств
Команда
Master Techs Участник Master Techs
Community
294 членов
Автор 942 руководств
Комментариев: 2
Where does the 4-pin ribbon cable for a backlit keyboard connect?
thomja1 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 17
За последние 30 дней: 73
За всё время: 10,506
