Введение
Keeping your laptop cool is important to the speed and functionality of the device. This guide will show you how to replace your Toshiba's cooling fans.
Выберете то, что вам нужно
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
2 участников успешно повторили данное руководство.
