Введение
This guide will show you how to replace your Toshiba's DVD tray when it is no longer working correctly.
Выберете то, что вам нужно
Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
Remove the hard drive from the tray.
Remove the ten 7mm screws located on the bottom of the laptop using the J1S screwdriver.
