Введение
The hard disk drive is an essential component to a laptop. This guide will show you how to safely remove and replace your hard disk drive when your device needs a new one.
Выберете то, что вам нужно
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
Remove the 7mm Phillips screw located on the back panel of the device using the J1S Phillips head screwdriver.
Locate and unscrew the five 3.5mm screws holding the hard drive in place using the J1S Phillips head screwdriver
Remove the four 2mm Phillips screws from the HDD tray securing the disk using the J1S Phillips head screwdriver.
Remove the hard drive from the tray.
