Введение
If your device has slowed down or no longer has saving capacity, it's time for an upgrade. This guide will show you how to replace your RAM (Random Access Memory) when you need to expand your device's memory space.
Выберете то, что вам нужно
Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
Remove the single 7mm Phillips screw holding the panel in place using the J1S screwdriver.
Remove the back panel using the opening tool.
