Введение
This guide will show you how to open up your device and remove the battery in the event that your device has power issues.
Выберете то, что вам нужно
Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
2 участников успешно повторили данное руководство.
