Выберете то, что вам нужно
Unscrew the 10 5mm Phillips screws, located on the bottom side of the notebook using the PH1 bit and the Magnetic Driver.
Pry open the bottom cover of the notebook with the plastic spudger tools. Slide a thin tool along the edges without ports to pop open the latches.
Remove the 1" yellow tape on top of the battery. This piece of tape is holding down the battery connection cable.
Lightly grip the battery on the two longest sides. Gently pull up until the adhesive on the notebook is separated from the battery.
Delicately pull on the hard drive and the case it's in to unplug it from the motherboard.
Peal the rubber casing around the hard drive off to completely remove the drive.
4 участников успешно повторили данное руководство.
4 Комментариев
What kind of joke is this?! Spent an hour taking my toshiba apart and THERE IS NO DRIVE IN HERE!!!! WTF
Do we change ssd hearddisk 240gb with same ram
I agree with Hammerjockey Radios, you guys should be more clear. there’s no drive on this model.
I started to think the drive was missing b/c my model is just -1204, not the 1204X version. But then I looked again at the pics above. There is NO DRIVE in their pics either! Not until steps 7-8 where you can see they layed one in there. Steps 3,4,5&6... There Is NO drive so why would you be taking the battery out? Even if there WAS a drive in this model, unnecessary manipulation of a lithium battery is not a wise move.
