Toshiba Satellite Click 2 L35W-B3204 Screen Replacement
Выберете то, что вам нужно
  1. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: шаг 1, изображение 1 из 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: шаг 1, изображение 2 из 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement, Screen: шаг 1, изображение 3 из 3
    • Begin by inserting the plastic opening tool into the lip that lies between the screen and the plastic housing and gently prying it open. The best place to begin the screen removal is the bottom left side of the screen.
    • Continue to work your way around the screen with the opening tool until all the clips are undone and the screen is free.
    • Lift screen off of plastic cover to expose the internal components.
  2. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: шаг 2, изображение 1 из 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: шаг 2, изображение 2 из 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Locate the wide, golden connection on the bottom of the screen. Use the black spudger to peel away the tape holding it in place.
    • Use tweezers to gently remove the plug from the screen.
    Please were can i buy a new screen?
    Jeremiah Lands - Ответить
  3. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: шаг 3, изображение 1 из 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: шаг 3, изображение 2 из 3 Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: шаг 3, изображение 3 из 3
    • Trace the black ribbon cable that begins on the right of the screen. This cable is connected to the upper part of the motherboard, which is located near the right speaker.
    • Using tweezers, gently grasp the plug on the end of the ribbon cable and remove it from the motherboard.
  4. Toshiba Satellite Click 2 L35W-B3204 Screen Replacement: шаг 4, изображение 1 из 1
    • Your screen is now completely detached from the internal components.
Заключение
2 человек успешно провели ремонт по этому руководству.
Lexi Lannigan
Участник с: 10/17/18
753 Репутация
Автор 6 руководств
Команду
UMass Dartmouth, Team S1-G4, Valliere Fall 2018 Участник UMass Dartmouth, Team S1-G4, Valliere Fall 2018
UMASSD-VALLIERE-F18S1G4
6 членов
Автор 12 руководств
Один комментарий
This instruction set was VERY useful, since it focused on the exact device that I have, and had great photos to accompany the steps. TC
Thomas Cirillo - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 1
За последние 7 дней: 2
За последние 30 дней: 10
За всё время: 1,657
