Введение
Before you attempt to follow this guide make sure you have all the required tolls needed for the removal of the fan. This may be challenging to be complete. Make sure you follow each step as it is listed.
Выберете то, что вам нужно
Remove the LED ribbon cable using ESD safe tweezers.
Remove the SIM card ribbon cable using ESD safe tweezers.
Remove the Docking connector ribbon cable using plastic opening tool.
Remove the LCD Display ribbon cable using a plastic opening tool.
Remove the I/O ribbon cable using a plastic opening tool.
Еще один человек закончил это руководство.
