Введение
To attempt this guide, make sure to have all required materials and tools. This guide is the longest and most difficult of all the guides. Requires your full attention in to properly replace it.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the battery power connector using ESD safe tweezers.
Remove the LED ribbon cable using ESD safe tweezers.
Remove the SIM card ribbon cable using ESD safe tweezers.
Remove the Docking connector ribbon cable using plastic opening tool.
Remove the LCD Display ribbon cable using a plastic opening tool.
Remove the I/O ribbon cable using a plastic opening tool.
Remove the power connector from the fan using a pair of tweezers.
Remove the 3mm screw J0 Phillips screw with the Philips screw driver.
Remove the black and white cables attached using ESD safe tweezers.
Locate and remove the five connectors using ESD safe tweezers.
3 человек успешно провели ремонт по этому руководству.
