Введение
The tablet battery is located inside the tablet itself and will require a Phillips head screwdriver, prying tool, and tweezers. Also, there are a few wires and screws that need to be removed that require patience and a steady hand.
Выберете то, что вам нужно
Take the pry tool and pry open the backing of the tablet around all four sides and pull off back.
Use a Phillips #0 Screwdriver to remove four screws in the corners of the battery pack.
Remove shown wires from clips on the left hand side of the battery before pulling the battery completely out.
Remove highlighted plug out of the circuit board before completely removing the battery pack.
4 человек успешно провели ремонт по этому руководству.
