Выберете то, что вам нужно
Remove the fourteen 3.75mm screws with a Phillips #0 Screwdriver as shown.
Using a spudger, poke the white tabs in by the battery until you hear a click.
Инструмент, используемый на этом этапе:Pro Tech Toolkit$74.95
Unplug both ribbons by flipping back the white tabs on either end of the ribbons and gently pulling the ribbons out.
Using the 0 Phillips Head, unscrew the two 3.75mm screws connecting the USB Port Circuit Board to the hard drive.
Remove the USB Port Circuit Board.
4 человек успешно провели ремонт по этому руководству.
