Введение
The motherboard is the base for all of the parts of the laptop to communicate with each other. When the motherboard is damaged such that certain functions of the laptop won’t work, then a replacement for the motherboard may be necessary.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the hard drive’s connection port with grooved tweezers.
Pry the heat sink away from the laptop with two hands at both ends and remove it from the device.
Remove the single 7 mm silver screw using a Phillips #1 screwdriver.
Remove the 7 mm silver screw under the metal bar using the Phillips #1 screwdriver.
